luvmydogs
Dec 11, 2017Explorer
Wet and mold
So's not to sound to stupid, this is the first time we are in the rv in the winter. Having a problem with windows, closets and compartments getting wet and then of course mold sets in. Is this normal ...
smthbros wrote:I want to increase the temperature of the inside walls -and be comfortable at the same time. Warm air holds more moisture than cold.
While increasing the indoor air temp will increase the surface temp of the outside walls, the main reason for increasing indoor air temp is to reduce the relative humidity..
