donn0128 wrote:
One word, DEHUMIDIFIER. Windows open help, but a large dehumidifier is what you need. Run it 24/7. You will be amazed how much water is removed. Also leave closet doors open when you can.
x2. course that only works if you have shore power.
and not one of the tiny tiny 12V dehumidifiers. get one of the small home dehumidifiers.
First day or so you may pull 5-10 gallons of water out of the air! then it will drop down.
and also keep vents open when you shower. and do NOT use an non venting propane heating unit. they will dump about 1 gallon of water in the air for every gallon of propane burned. your furnace is ok, it's exhaust vents outside. but the oven and cooktop do produce water vapor.
and the human body produces a lot of water vapor just from breathing.
