How often should wet bolts be greased. We just had them installed last spring. We travel about 10 000 miles a year. Trailer has only gone about 2 000 since the suspension mods. Thanks
If the spring bolts were installed correctly, the hole in the pin will be located on the bottom so the grease will actually be applied on the wear side of the pin and bushing. As mentioned above, raise the coach up by the frame and let the axles hang, then grease the bolts. This allows the grease go where it is needed most.
