rhagfo wrote:
Houston Remodeler wrote:
As a former Yankee, I can swear the chains will make things worse or just as bad. Boards are the way to go, but you'll need quite stout boards.
When you have the time bury thesethese in the grass They are often buried around office buildings so the fire trucks can drive right up to the building.
There is also a cinder block that also allows grass to up through yet provide a solid surface and cost less.
I have looked into the honeycomb stuff before. I think you can get it something like the squares but actually comes in a roll. Not cheap either way.
I'll look into the cinder block type.
I counted turns tonight, If you count each forward movement and each backwards movement separately, total was 7.
