jaycocreek
May 06, 2019Explorer II
Lol, wut??
No they don’t.
Who’s does?
2012 Ram 3500 Laramie Longhorn Mega Cab DWR payload 2460
Specs and Dimensions
Compression ratio:17.20 to 1
Engine horsepower:350hp @ 3,000RPM
Front headroom:1,041mm (41.0")
Rear legroom:1,151mm (45.3")
Exterior height:1,989mm (78.3")
Front legroom:1,041mm (41.0")
Interior maximum cargo volume:2,044 L (72 cu.ft.)
Exterior length:6,309mm (248.4")
Engine torque:800 lb.-ft. @ 1,500RPM
Front hiproom:1,605mm (63.2")
Payload:1,116kg (2,460lbs)
Passenger volume:4,055L (143.2 cu.ft.)
Turning radius:7.1m (23.4')
Front shoulder room:1,676mm (66.0")
Wheelbase:4,077mm (160.5")
Towing capacity:5,806kg (12,800lbs)
Engine bore x stroke:107.0mm x 124.0mm (4.21" x 4.88")
2011 Dodge 3500 DRW payload 2530
Compression ratio: 17.20 to 1
Engine horsepower: 350hp 3,000RPM
Rear legroom: 1,151mm (45.3")
Payload: 1,148kg (2,530lbs)
Front headroom: 1,041mm (41.0")
Turning radius: 7.1m (23.4')
Passenger volume: 4,055L (143.2 cu.ft.)
Ford F-150
A 3.5L EcoBoost® V6 engine provides the most towing capability at 12,100 pounds and 3,230 pounds of payload when equipped with 141” wheelbase, 18” wheels, and the Heavy-Duty Payload Package
44,071 PostsLatest Activity: Aug 16, 2026
