jimh406
Jun 07, 2019Explorer III
Congrats.
You need a way to plug in the lights.
Leave your tailgate at home.
Air up your tires or have a way to do it once you get there.
If you put something in the front of the bed, make it thick although I never have.
Make sure the cab isn’t too tall if it is an older Adventurer that was made before the cabs were taller.
Bring holding tank additive if you plan to use it. Bring freshwater additive to put in the fresh holding tank. Or, look up where to buy the stuff on your trip back.
Understand how to tighten the spring loaded tie downs and make sure they aren’t too tight to cause damage.
Bring sheets etc if you plan to sleep in it instead of immediately driving straight back.
