4x4ord wrote:
I don't like changing oil so I use AmsOil and run it 15,000 miles between changes. I figure my truck will be about worthless by the time it is 10 years old regardless of how I treat it and in 10 years I doubt I could wear the engine out with the amount of miles I put on a truck. If I was bent on changing oil every 5000 miles I would use a less expensive diesel oil. We use Rotella T triple protection in our other equipment and most of it runs very hard and under severe conditions for 600 hrs between changes... as per manufacturer's recommendations.
I run my wimpy little gasser 7500 miles between oil changes per the onboard OCI. What diesel oil is so inferior that it needs to be changed every 5k miles? Isn't the OCI for the newer diesels 15k using any manufacturer approved and API certified engine oil? Has anyone here suffered a catastrophic engine failure due to not using a specific brand of oil?
