carringb
Sep 21, 2016Explorer
I think that motor is too underpowered for those trailers listed. But if you're patient, and PULL OVER when you're holding up traffic, it can probably do it. I just don't think it will be all that enjoyable.
GCWR is 13,000 pounds so you're probably ok there, depending on the actual loaded weight of your van.
Beware of trailer dry weight. They don't include options, propane, batteries etc so actual empty weight can be quite a bit more than the "dry" weight, even before you add water and cargo.
