ScottG
Apr 21, 2015Nomad
Yes, the steering cooler is needed because you will be using the vehicle outside its design criteria. This is because you will spend an unusual amount of time maneuvering a trailer into t a camp site. Al that backing requires a lot of slow speed turning which is a load on the PS system and creates lots of heat. A scenario the original vehicle was not designed for.
You may be able to get away without it but in my mind it's worth doing it right to keep you from being stuck someplace with a failed component.
Many Mini vans and other vehicles require it with the "towing package" as well.
