Gdetrailer wrote:
Oh, yeah, by the way, you CAN fix those softspots that they will never come back again.
Once you have cut out and replaced the soft subfloor, you now lay a layer of 1/4" luan over top of the floor and put down new vinyl or new carpet. You simply glue and nail down the luan and that added layer reinforces your floor. Yes, it adds 1/4" to the floor height but it should be no issue. You do not have to laydown the extra layer under cabinets or any other immovable object. Only needs to be done where you walk.
These things can be fixed much easier than you think.. That is a weekend project and if you are slow at it perhaps a 2 weekend project.
The soft floor is generally a structural problem. 1/4 plywood is not known to be very sturdy or structural. It generally used to create a smooth surface but it's not used to provide substantial structural integrity. The only thing 1/4" plywood may due is mask the problem and buy some time until the softness returns.
If you decide to overlay with 1/4" it needs to be done not only in the areas you walk but it needs to be done wall to wall. If the new plywood ends at a cabinet is there ample support at that seam?
cross your fingers and hope...LOL.
By the way are you screwing this 1/4 plywood into joist or are you just screwing it into the existing compromised panels?
In closing soft floors are unfortunately a all to familiar isue especially in lighter weight RV's.
The fix is not easy. The real solution is to build the RV's using a better technique in the first place.
There are fixes that can be done after the fact. But they are generally not simple,foolproof or universal. Each case is different and will require a different approach depending on severity
