- mkirschNomad II
BigSwick wrote:
Cirrus is using a retractable type ratchet strap on the 620 model. Weight of camper could be upwards of 2500#. They are mounted on the camper and attach in the bed tie downs. Thoughts?
First, what does this have to do with the rest of this 5 month old thread? It's not even about a Cirrus camper.
Second, as long as the ratchet straps are rated to handle the load, sounds like a great idea to me. You're not hanging the truck from the camper. You're just keeping the camper in place. - mkirschNomad II
StirCrazy wrote:
still way overpriced for what you get. yes it has a strong fram and is insulated good but thats where it stops. cramped, no real toilet or shower. I think this would be apropreatly priced at 1/2 there asking price and thats only because of the solar and such that is intragrated into the camper roof. there are a lot of things I like about these and a lot I don't. If the price was more realistic compared to other campers, I would concider one myself.
You try building that for production for less.
This is really a problem with any newcomer and what dooms most of them to bankruptcy. Each one is hand built in a shop bay, not on a production line like a large manufacturer such as Lance. There's no economies of scale to be had. You're going to pay more for less (space, amenities, etc.). It may be better quality. It may be lighter, stronger and made of space-age materials. People still shop for cheapest price. - StirCrazyModerator
silversand wrote:
NRAlifr wrote:
You’d think that for a >$100K truck camper, they could have found a way to squeeze in a cassette toilet at the least.
....that is CAD. Their shop is about 140 kilometers from us. What is that in USD? Something like $74k USD today. Not too bad, considering that the $100k CAD model has in the vicinity of $45,000 in accessories in and on top and on back of it.
We are following a Quebec couple (young couple, probably in their mid 30s) who bought a LOKI. While their rig is being cultom-built, their last Youtube vid showed them with a LOKI loaner this winter.
I recall seeing the "jacks" being retractable into the camper shell, kinda like landing gear on an aircraft.
Steve - BigSwickExplorer
Cirrus is using a retractable type ratchet strap on the 620 model. Weight of camper could be upwards of 2500#. They are mounted on the camper and attach in the bed tie downs. Thoughts? - silversandExplorer
I recall seeing the "jacks" being retractable into the camper shell, kinda like landing gear on an aircraft. - ajridingExplorer IIdiesel stoves and heaters run off your already filled vehicle diesel tank, for those driving diesels, or off an aux tank for gas trucks. Diesel is a very safe fuel, about as volatile as cooking oil.
The stove works on diesel, but all the exhaust goes outside unlike a propane stove that burns inside. The diesel burns under the stove burner and heats the plate (the circle) and heats the pan. Popular in Europe where they have a lot of diesel vehicles.
Induction cook tops are a nice option for quickie cooking, like coffee or eggs or heating water, but not ideal for meals that require a long time on the stove. They use a lot of battery power, but for short meals and sufficient battery supply (and solar probably) this is not a problem.
If I had it to do over I would install a diesel heater and use induction cooktop and just carry a portable camping stove for backup. Then I would not need a big propane tank mounted anywhere nor a need to fill it/ exchange it. I have a DC fridge, so would need a little bit more power than I have now (old batteries) just in case to make it thru the night without running batts too far down. Very very doable though.
Yes, taking off the legs and finding storage is not easy, there really is no place to store them that is good, but go off road and you have no choice other than to leave them home, or mount them upsidedown, but then you have to worry about tree limbs. If you get serious then consider building a mount on the rear of the camper to bolt the legs to that is safe and out of the way, yet ugly...
Smaller TCs have internal tie down points and are accessed thru a door inside the TC to the truck bed. - mellowExplorerMaybe they use the D-Jacker system?
https://www.truckcampermagazine.com/news/d-jacker-system-for-rieco-titan-jacks/ - notsobigjoeNomad III
NRALIFR wrote:
notsobigjoe wrote:
I'm asking because I do not know. What is the advantage to the diesel fuel heater and stove. Doesn't diesel stink and it's a little hard to deal with as far as my own observations..
I should have included a link to that. The diesel fueled cooktops are a solid surface unit that is very similar in design to a propane furnace in that it exhausts it’s fumes and excess heat to the outside. Since they are apparently already supplying diesel fuel to the water heater/furnace via either a connection to the truck fuel system or an onboard tank, that could also supply fuel to a diesel cooktop.
I’m not fond of a single-source of energy for RV’s for the same reasons I have never wanted a total electric home.
EarthRoamer uses these in their units, BTW.
Webasto Diesel Cooktop
Webasto Dual Top ST Air and Water Heater
Thank you for the info, it is interesting. I like your point about not putting all your eggs in one basket. I have the usual lance 1181 setup in mine that really surpasses all my needs. I've said before that I don't and have never boondocked, there is no reason behind that statement I've just never done it. With that said perhaps it's time to look into some of the solar options as I now have my truck and camper ready to bug out on a moments notice. Solar would probably be more useable in a bug out situation for me. I'll pass on the diesel and stick with propane only because I would never get a new enough camper for such things. It's a good thread, I always liked these informative ones. - BigSwickExplorerThey also are using 12 volt AC and heat. I would think that would take lots of battery power.
- NRALIFRExplorer
44,071 PostsLatest Activity: Aug 30, 2026
