Old-Biscuit wrote:
You have a 2013 year trailer so your Atwood WH uses one set of t-stats for both electric & propane and uses a DC circuit board to control power to the electric element and propane gas valve.
Neither heat source working and LIGHT ON ........that light is a FAULT (failure indication)
In outside compartment is a thermal fuse (comes from circuit board & goes to t-stat----has plastic tube on it)
When it trips (one shot device---has to be replaced) it shuts-down ALL dc power so neither heat source will function.
It trips at 190*F caused by flame blowing back out of combustion chamber (spider webs/mud dabber nests etc.)
You can remove it and plug brown wire from circuit board onto terminal of t-stat...then turn ON/OFF switch OFF to reset fault then turn back ON to test fire. (Use propane so that you can hear/see main flame light off.
IF that 'fixes' issue.......buy a new thermal fuse and replace it.
Clean out combustion chamber.
Enjoy hot water :B
Thank you, thank you. Saved me a lot of time and hit the tail on the head. Thanks to everyone for there suggestions also.
