blt2ski
Aug 25, 2019Moderator
Chris, you only get to call it a 1.5 ton when you can put two 4' long pallets end to end in you bed! Otherwise, it's just a grocery getter! :B
As far as the rest of this goes.....has not mattered since I started buying trucks in late 70s. I've seen 6 lug GM 2500 badging, a dually with 9-10k gvwr door stickers. I licensed on at 16K, legal at 16K too! Full floating axles STOCK mind you in GM 1500 series truck. Should also note, this is trucks from about 1975 on!
I have to license my trucks, as does Chris at 1.5 times empty weight to next highest ton. BOTH of us have had 25/35 series SW trucks that weigh 7000 lbs, manufacture gvwr at 8600-9900, with legal max GVW registrations to 12,000 lbs. Been thru enough scales over manufactures gvwr, with out getting a overweight ticket, to know none of the manufactures badging, specs etc matter when it come to the person with blue lights on roof of vehicle. It only matters to the RV.net weight police. OR, as is the case hop err fully with OP, wants to know story behind terms.....which happened in a galaxy a long time ago! :):):)
Marty
Marty
44,071 PostsLatest Activity: Aug 30, 2026
