JRscooby
Aug 29, 2019Explorer II
ShinerBock wrote:
Yes, it is opinion. Just go to the GM forums and see them debate whether a 2500LD was actually a 3/4 ton. Half say yes, and half say no. Then there is the Ford light duty F250. Half say it was a 3/4 ton and half say no. Then their is the F350 that gets de-rated into a 10k GVWR. Most say it is still a 1 ton while others say it is now 3/4 ton. Then there is the F250 with the camper package which essentially gave you the exact same truck, suspension and all, as an F350, but with an F250 badge. Some say it is still a 3/4 ton because of the 250 badge and others say it is a 1 ton because it has the exact same components as the F350.
So yes, it is all opinion.
Friend of mine had a cab fire in a old F-750. A few weeks later, one of his F-250s was rear ended hard. Then he needed to downsize his company, sell a bunch of equipment. We put the cab off the 250 on the other truck. Weight watcher looks at cab ID number, no issue for no CDL...
44,071 PostsLatest Activity: Aug 30, 2026
