gmw_photos
Aug 29, 2019Explorer
What I am most concerned with my trucks is axle and tire rating, GVWR, and what level I have to register it.
For instance, in my state, I have to run a 12K plate on my Frontier, because with the funfinder hooked to it, I weigh 8500 combined. Because of that, I cannot run just a 6K plate. If I never towed anything with it, I could run a 6K registration.
The reason we "pay" for the weight of the trailer in the truck plate is because our trailers get a "permanent" (one time) plate, and the cost of that registration is basically just a paperwork cost.
If you look under the rear of a F350 SRW vs a DRW, the pieces and parts are the same, yet the DRW has a much higher axle and gross rating. The limiting factor on the SRW is the tire capacity. My dually has a 9K axle rating, where the same truck that year in a single was 6K.
The payload on my F350 is 4800 pounds. So I guess that makes it a nearly two and half ton truck. Sometimes when running empty, I think that's an appropriate designation !
I suppose eventually people will drop this idea of calling these trucks out as half ton, one ton, etc. Old habits die hard.
44,071 PostsLatest Activity: Aug 30, 2026
