- CavemanCharlieExplorer IIII have mine in the heated shop. I built a mount and added 2 new 6 volt golf cart batteries instead of a single 12 volt so I can extend my dry camping time. I greased the front jack, oiled the stabilizer jacks, washed the windows, looked at the roof, cleaned the filter on the AC, turned the fire extinguisher upside down and pounded on the bottom of it to loosen the stuff in it, cleaned and reorganized the storage compartment, checked the escape hatch, and finally I replaced and packed all the wheel bearings. You can buy new ones for 15 bucks a wheel for the whole set including the seals, and since you wreck the seals and need to replace them when you pack them anyway it's just about as cheap to change them all out.
I also put new shocks on the rear of my pickup. One of the old ones had gone bad. - DenlorExplorerBought surge protector, leveling blocks and can't wait to use them as we pick up our new Zinger 33FK next month. Been a long winter and when summer here is done headed to AZ.
- mike54Explorerbearings repacked, brakes cleaned and adjusted and Bal lock arm stabilizers installed. :B
- pdmac1946ExplorerClosed the deal on a new 2013 KZ Sportsman 270RKSS 29 ft ultralight trailer today. My first brand new rv. Can't wait to bring it home.
- mikedboydExplorerTowel hooks and paper holder in the bath. Finished trimming the interior of the new outside baggage doors to under the dinette benches. Picked up the broken glass inside the overhead cabinet (plastic glasses only, I guess).
- rightyouarekenExplorerReplaced the stock flimsy plywood dinette booth seat tops with stronger stuff, installed durable carpetting in the front pass through, and installed a Camco vent cover on the bathroom roof vent.
- WoodGlueExplorer
sbowman871 wrote:
WoodGlue wrote:
I just bought some new sheets and I hope they work the way they're supposed to:
Platform Bed - No Tuck Bed Sheets
The top sheet is sewn onto the fitted sheet and it's not supposed to pull out of the bedding.
When I receive them, I'll try them out and report back on the comfort and durability of the sheets, etc.
WoodGlue
Any update on how the sheets worked out? We need to get a better fitting set for our mattress.
The bed sheets fit nicely and correctly! - CeciltExplorer4 new Maxxis 225/75/15 load D tires today and installed the Tire Tracker TPMS system
- WoodGlueExplorerI'll check on the sheet set in about an hour from now and report back as to the fit and comfort!
WoodGlue - BourbonRamExplorerJacked her up and tested (for the first time) the breakaway brakes. They work.:B
44,059 PostsLatest Activity: Mar 18, 2026
