- dodge_guyExplorer IIJust curious how the hitch is rattling? When using a WD hitch it’s design is such that it won’t rattle!
- TvovExplorer IIThis is new to me. I've got older hitches that are a little loose, but whenever anything is hooked up there is no rattle. I don't recall hearing any rattle from the hitches when not towing.
Having said that... now that I think about it, I do have a little noise every so often from my truck at low speed... I wonder if it is the loose hitch? Hmmm... - AtleeExplorer III must be hard of hearing. That one rattle I've never heard.
- LarryJMExplorer II
DesertTracker wrote:
x2 on the Hitch Rider Hitch Vise. Quick, easy install and very effective.
X3 and I would wager a small bet that like IAMICHABOD discovered is that any other type of "anti-rattle" - "vice" type design is not going to be that effective with WDH systems and heavier trailers. I've now been using the "hitch-vise" for close to 9 years and have been very happy with it's performance.
Larry - DurbExplorerAnother positive on the Stowaway. I used it on a curved Andersen aluminum stinger so I had to mount it from the side. Worked perfectly as it is a heavy duty item.
- DesertTrackerExplorerx2 on the Hitch Rider Hitch Vise. Quick, easy install and very effective.
- GordonThreeExplorerI ended up just hammering some flat washers in under the ball mount after it was pinned in place. Maybe they'll work loose someday, and if they do I'm out $1, but it has worked. I'm one of those lazy guys that leaves the ball mount in all the time. Although it has a removable ball holder, and I do take that off sometimes.
- IAMICHABODExplorer III have tried almost every Anti Rattle device on the market, most have been no good or so complicated and cumbersome that they are useless. Including the Roadmaster type,totally useless.
Until I found the one at Hitch Rider.
Their Hitch Vice is the best and easiest one I have come across and it really works. - LwiddisExplorer IIda u.s. mail? as in the giverment?
- wanderingbobExplorer IITHANK YOU , got one , it is in da mail .
44,043 PostsLatest Activity: Jul 24, 2025
