- sbowman871ExplorerBlaster cleaner. Get the grease off. Grease / oil picks up sand, dirt and debris that just jambs up the Jack screw. Clean off the grease and use a dry lube.
- wmosesExplorerLippert stabilizer system manual says "No grease or lubrication is necessary and in some situations may be detrimental to the environment and long term dependability of the system." (Lippert manual)
Makes little sense to me, especially on the steel-steel interfaces. - Since I have a super glide , I always have a can or 3 of slip plate laying around... Any type of dry lube works well...Joe
- crcrExplorerWD-40
- campiglooExplorerI use the same products rbpu uses and the same wash method. I have found that chain lube works and lasts a little longer than some.
- Community AlumniI spray them with a silicon lubricant.
- rbpruExplorer III use about any spray on lube. It all seems to wash off in the next rain storm I drive through. :W
- beemerphile1ExplorerWD40 a couple times a year. Helps to prevent rust and provides a little lubrication without making them oily/greasy.
- n7bsnExplorer
Old-Biscuit wrote:
Dry graphite spray....goes on wet then completely drys in minutes.
Stays on, lasts and great lube
Yup, furniture polish is NOT a lube, it's a wax finish. If you this it doesn't attract dirt, ask your wife ;)
BTW, the dry "teflon" works well too - Old-BiscuitExplorer IIIDry graphite spray....goes on wet then completely drys in minutes.
44,049 PostsLatest Activity: Aug 27, 2025
