SoonerWing03's avatar
SoonerWing03
What does this mean???
One of the TT's that I am considering has the following weight ratings (taken from the stickers on the unit).
UVW: 5020 lbs
GVWR: 6500 lbs
Max Cargo: 1440 lbs
2 axel's each rated at 3500 lbs
My question is this, if the axel's can support 7,000 lbs, why would the GVWR be 6500 lbs? Does this mean that the frame is not strong enough to support more? Or does it mean that the tires cannot support that much weight? Or neither?
  • So with that said, if I upgraded the tires could I effectively increase the cargo capacity?
  • All of the above. GVWR is the sum of the weakest component. Could be tires, wheels, axles, or springs.
