valhalla360 wrote:
It's a battery charger. Never made sense why RVs use a different name.
Yes, you can draw off it directly but you can do that with a battery charger too.
That is not entirely correct. You cannot (safely) draw directly off of a battery charger because it is not regulated. A battery charger's output varies depending on load. It can start out at 19V or higher with a very light load (or on the high-Amp charge setting) and drop to below 11V with a heavy load.
IF what you are trying to run isn't terribly voltage-sensitive, then sure. However sensitive electronic devices looking for a 12V input are going to have problems on raw 19V+ from a battery charger.
A converter has a regulated voltage output. It is called a converter because it CONVERTS 120VAC to 12VDC, the opposite of an inverter which INVERTS 12VDC into 120VAC. Not all converters are battery chargers, as pointed out above.
