Bruce_H_'s avatar
Bruce_H_
What is a "Grown Tire"?
Last December I upgraded my trailer tires from Trail America to Maxxis M8008, and also increased one size from 205/75R14 to 215/75R14. At the time I was concerned about wheel well clearance with the larger tire size, which has a radius that is 0.3" larger. Later on, based on my own studies of Dexter tables for torsion axles and communication with the trailer manufacturer, I concluded that there would be at least 1/2" clearance between the new tire at shock load and the wheel well.
After each camping trip I inspect the wheel wells for any evidence of scuffing. Until this last trip, no evidence of scuffing. On this last trip, I was heading North out of San Jose on a California freeway and encountered an area of the right lane where there apparently had been some ground slippage. The area suddenly dipped about 6" and continued for perhaps 30 to 50'. I was going between 55 and 60, and I felt the Pilot's suspension solidly bottom out. Well, I thought, this will be a good test of the TT's wheel well clearance.
When I later inspected the wheel wells, there was some light scuffing. I am trying to understand how this happened. Perhaps Dexter's tables are wrong and the Torflex spindles moved more than they calculated.
I see in a table in Barrystiretech from the Tire and Rim Association that a "grown tire" in the 215/75R14 class will increase its diameter by 0.55". Perhaps that is also a contributor to the problem, but I really don't know what a "grown tire" is. Does it refer to a tire temporarily increasing in diameter due to centrifugal force? Does it refer to an aging tire losing elasticity and just "growing" larger?
Just trying to figure this out.
Thanks,
Bruce
  • A "grown tire" is exactly what the term implies: a tire that has grown (maybe "stretched" is more apt), usually due to use.
    It's not a temporary condition.
