Ron Gratz wrote:
Francesca Knowles wrote:
ECones wrote:
We're looking to buy a TT with a dry weight of 4178 pounds, but there's a sticker on the door that lists a weight in the 4550 range.
The number you need concern yourself with is the trailer's gross weight, which must be gleaned from mfr. specs by adding two figures together: the "pretend" dry weight plus the listed carrying capacity.
The trailer's "gross weight" (a.k.a. Gross Vehicle Weight) is what the trailer actually weighs when loaded for camping.
The GVW is not gleaned -- it is measured on a scale.
If you meant to refer to the trailer's Gross Vehicle Weight Rating, that does not have to be gleaned either --
it is stated on the certification plate for an existing trailer or in the manufacturer's specs for the different models.
Ron
A lot of times the GVWR has to be gleaned from mfg. spec/brochures cause they don't list GVWR.
They list 'shipping weight' and 'carrying capacity'
Now if you can actual see the trailer..then the data plate will have GVWR
