spoon059
Feb 26, 2018Explorer II
We went from a 22' to a 31' (box measurements) and it is a big difference but you quickly learn. The newer camper has a slide and therefore sits up higher and has more ground clearance. You'll learn to swing wider for turns. You'll learn where your tail end is and when you can pass vehicles. If you have enough truck (you want a 3/4 ton at least with that length) then wind shouldn't be an issue.
Find the floor plan that fits you and don't sweat it. You'll figure it out... we all do!
44,056 PostsLatest Activity: May 04, 2014
