4x4ord
Feb 24, 2019Explorer III
If you can change your order to a F350 SRW you should. The price should be within a few hundred dollars. If you can't change the order you could add an overload spring to your rear axle and ignore your truck's gvwr. The gross weight of the fiver will not hurt anything on your truck. It is the pin weight that is of concern.
44,066 PostsLatest Activity: Mar 14, 2015
