Kayteg1 wrote:
When I bought my camper I was under assumption that the floor- being main structural component is 1 1/8" plywood. That did not to turn to be truth...I have factory rubber mat on my Ford and it does good job.
Oof! The PO of our camper said "no rot." We didn't believe him as, every version of this camper we had researched needed major fixes to correct rot in the floor and wings. No surprise: there is lots of rot.
We are definitely looking into a friction mat for the truck bed!
Reddog1 wrote:
There is a Avion camper rebuilds - hundreds of photos thread you may find of interest.
Thanks Wayne! Fortunately, we did read that thread before The Great Photobucket Debacle. ;) We did a lot of research before buying the Avion. It really is unfortunate that we don't have the pics, though, for future reference.
SidecarFlip wrote:
Mine is 3/4" plywood overlayed with waterproof paint and I have 3 roll formed steel channels running parallel with the camper and one across the back screwed into the floor every 1 1/2".
That is fascinating! I don't think I've seen anything like that before. Do you have any pictures of the steel channels?
work2much wrote:
I'm not sure I would go fiberglass. Is is flexible enough to handle differential loading when the camper is flexing around on jack stands? The bottom of many wood or aluminum framed campers is just a belly pan and not a structural part of the rv. They are often thin to save weight. If plywood was there before I would consider replacing in kind with high quality plywood. Apply wood sealer before install.
That is a fair point! I definitely wouldn't replace the floor with just fiberglas. Ours, in particular, forms the foundation that holds together the ends of the arching aluminum which forms the walls and ceiling like an Airstream. Fortunately, we are using a fiberglas foam composite that has the structural strength of plywood but lighter weight and rot resistance.
Reddog1 wrote:
SidecarFlip wrote:
Reddog1 wrote:
I would just put everyday plywood or strand board, probably 3/4" thick. Paint it with a good deck paint. I would put 1-1/2" x 1/8" angle iron around the bottom edges, mounted with countersunk screws. This is just to protect the corners. I would caulk the angle iron.
Wayne..
I think I'd use aluminum angle versus iron for the rust factor and miter the corners and caulk with Dicor.
I think that would be over kill. I am sure someone is going to suggest marine plywood and stainless steel screws. More over kill in my opinion. I don't have aluminum, stainless or marine plywood in my home.
All good points! We are, actually, leaning towards overkill, though. After all, we don't have a large store of our own materials, so we buy what is needed, be it stainless steal and aluminum or otherwise. Galvanic corrosion from steel and aluminum has already eaten large holes in the body that we are patching, so we are in favor of putting in the extra effort to give this little lady another 50 years ;)
GoinThisAway wrote:
The bottom of my Bigfoot is fiberglass. I did have an issue with slippage side-to-side until I made a pair of removable plastic boards that both help me align when I load and keep it from slipping.
Are those attached to the bottom of the camper or do you lay those down in the truck bed?
1mtnman wrote:
I bought an older Hallmark truck camper that I rebuilt. The plywood on the bottom was totally rotted out along with some of the super structure. I used 3/4" plywood to replace the bottom. I rolled 3 coats of Flexseal on prior to attaching the plywood to the camper. Flexseal is not cheap but it is a great product. I got mine at Lowes about $75.00 per gallon but have 1/2 can left.
I'll go check that out! Did you add any extra slats / runners / rails to the base to aid drainage or is your bottom completely flat?
Reddog1 wrote:
I have a Bigfoot molded fiberglas TC. I think I have used everything posted on RV.NET since 2004, and the horse stall mat has worked best for me. No guides, standard tie downs, and also with a Stable Lift. My daughter and son in law also used it with their SixPac TC on their flatbed truck, with no guides.
Thanks! I've seen mention of horse stall mats a lot while researching this. Do you have similar experience with generic friction mats?
mountainkowboy wrote:
My 1990 S&S had a basement made of 3/4 plywood and was only designed to be used on a truck
Interesting...Is there anything on the bottom to aid truck bed drainage?
