wsc7050's avatar
wsc7050
What is the "cold" temperature for tire inflation?
Hello quick question. My trailer tires instruct me to use 65 psi when cold. Well some days I start in the 30's and some days in the 70's. And for argument sake, let's say both of those days end in the 90's. I know from using my tire temp and pressure monitor that if I put 65 psi in at 30 degrees and ran it to 90 degrees it would be different than if I put it in at 70 degrees and then ran it to 90 degrees. So should I be aiming for 65 psi for the temp I would spend most of the day towing at, or?
Thanks in advance!
  • Cold is cold. Don't stress about it like some do on here.
    When I raced circle track the tires went from 85 degrees to almost 300 degrees. The most I have seen in temp difference is about 6 degrees. That's with air and not nitrogen.
    You will find some on here that want to split the hair of the hair of the hair. Set them to max pressure cold and go on vacation.
