kennyd63ExplorerJun 02, 2014What is the maximum water pressure ?What is the maximum water pressure that any T.T. hot or cold water pipes will take when hook up to city water? I know use a pressure regulator. Which I do. Thank you all-:@
ckwizard777ExplorerJun 02, 2014I have Pex tubing and I run it around 50-55 with a Watts regulator but I have been known to crank it up to 70-80 when showering.
Related ContentWater pump?Water Pressure RegulatorMaximum Tire PressureMaximum towingLow Water Pressure
