Sparkndeb wrote:
So, after months of looking for a TT for my 2013 Tacoma to safely tow< I'm still confused about the GVWR. On some models the dry weight is say 3155 lbs with the gvwr at 5890lbs. So, I can put 2735lbs in the trailer? Who carries that kind of weight? What am I missing here? I need my gvwr to be around 4500lbs or so (I think). Help!
Your assumption is correct but what you are missing is that dry weight is a nearly fictional number and is always more than stated. GVWR on a TT is the absolute most the trailer can ever weigh at any given time as established by the maker. BTW, you would be surprised how much weight you can add to a TT when you start adding gear, water, etc.
