Huntindog
Mar 16, 2018Explorer
Viperpoker wrote:Minimum is the key word. GM has stated that they rate their trucks to the performance level that their customers have come to expect. That happens to be a higher level than the j standard. This can be seen in the many tests where GM smokes the competition at their rating.
i believe all three use the same ratings system now.
The new standard lays out minimum performance standards for acceleration, braking and handling. There are parking brake tests and grade-launch standards. The trailers used to conduct all such tests are spelled out specifically, and they must be ballasted and connected in a specific way.
And J2807 sets a minimum speed for the truck-trailer combination when climbing a specific mountain grade — the so-called "Davis Dam" grade that climbs eastward out of the Colorado River valley at Laughlin, Nevada. Cooling systems must bear the strain of the 11-mile trip when the outside temperature is at least 100 degrees and the air-conditioner is set to full blast.
What are you getting that exceeds GMs rating?
I have been looking at big THs as well, and haven’t seen any that a GM could not tow.
44,066 PostsLatest Activity: May 18, 2026
