Cummins12V98
Feb 07, 2019Explorer III
Viperpoker wrote:
It looks like the weak link was the transmission and non engine items. And all of you that said things like GM just doesn’t want to get in a pissing match, or GM intentionally underrates the towing numbers, had no clue. Engine, hp, torque did not change. Upgraded trans, axles, ring gears, drive shaft, and frame. Tow rating up to 35,500. 12,000 more than last year. Huge difference between 2019 and earlier GM trucks and this new 2020 model. Much more truck, as ram and ford have already been for a while.
The Silverado HD’s 6.6L turbodiesel V-8 makes 445 hp and 910 lb.-ft. (1,243 Nm) of torque, which is unchanged from the previous generation and short of the 1,000 lb.-ft. (1,355 Nm) generated by the Ram 2500HD with its Cummins 6.7L High Output turbodiesel inline 6-cyl.
But GM hooks the Silverado HD to an all-new Allison 10-speed automatic transmission, which together with upgraded parts such as larger and stronger front and rear axles; larger ring gears to both 2500HD (11.5-in. [292 mm]) and 3500HD (12-in. [305 mm]) models; and 30%-larger prop shafts helps enable a 52% increase in maximum towing capacity to 35,500 lbs. (15,876 kg). The Ram HD’s tow rating is 35,100 lbs. (15,921 kg).
Other Silverado HD upgrades include a stronger frame, which delivers a higher gross combined vehicle weight rating of up to 43,500 lbs. (19,731 kg). A 28-in. (711-mm) diameter variable speed fan, which is 2.5 ins. (64 mm) larger than the one it replaces, will help keep the turbodiesel cool under all that load.
Myself and MeAgain certainly were NOT part of the below comments. :B
"And all of you that said things like GM just doesn’t want to get in a pissing match, or GM intentionally underrates the towing numbers, had no clue."
Plain and simple GM could NOT pass the SAE forward and reverse repeated hill test.
44,066 PostsLatest Activity: May 18, 2026
