Viperpoker
Feb 08, 2019Explorer
ShinerBock wrote:Rocknita wrote:
ShinerBock I usually like to read your posts. I believe you’re very knowledgeable. But it seems as though you’re having a bad day and taking it out here. It seems the “pissing match” is you versus everyone else here. My very uninformed opinion is most of us don’t need to tow 30,000 lbs but we like having a truck that is capable of more than we need. Also these trucks have new features besides new towing/hauling capabilities. And as to the point about braking, all trucks rely on the trailer brakes to stop. I’ve never once brought up how much my trucks could tow but every truck I’ve had was more capable than the last. Certainly not going to whine about that.
My complaint is that a brands highest tow rating is worthless in a shop bay. I have had more recalls on a truck that is rated to tow just 17k then any truck I have ever had. My brother has the exact same truck and year and has a water pump fail on him under 50k and the same recalls.
My take is, instead of spending the R&D money to keep besting each other in useless tow ratings that a very very small portion of their customers even tow, they should have instead spent it on making the truck more reliable at the current ratings it can tow for most customers. I would much rather have a reliable truck that is rated to tow 17k than a less reliable truck rated at 35k.
As I said before, I have worked for engine and truck manufacturers before and I know how their budget for each section usually works. To keep costs low, you have to take away or decrease the budget from one area to focus on others. Or you focus on multiple places and increase the cost on all of the trucks.
Lots of money and time was spent on the frame, and other things to get to these new worthless for most customers tow ratings. Money that is either taken from other areas that make the truck more reliable or spread out among all the trucks (even those that aren't rated to tow 35k) increasing the cost of each truck.
I say at the very least they should have kept the previous years 30k tow ratings(since 99.9999% of their customers don't even tow that much in a light duty truck) so they didn't have to spend more money and time on those things. That way, more money and brain power could go into making the truck more reliable and efficient at the current ratings so owners don't have to keep sending their truck to the dealer every other month for recalls. As I said, I would much rather have a reliable truck that is rated to tow 17k than a less reliable(and/or more expensive) truck rated at 35k.
This year a Chevy 3500 dually work truck costs about the same as a ford or Ram but it is down about 9,000 lbs give or take in towing capability. I strongly suspect that in 2020 the Chevy will once again cost about the same as the ford or Ram, but will be able to tow as much or a little more than its competitors.
I’m assuming you have a 2500 3:42 pulling that 14k trailer.
44,066 PostsLatest Activity: May 18, 2026
