ShinerBock wrote:
Viperpoker wrote:
Ram added an Aisin transmission to make their numbers go up. The engine also has increased from 800 to 930 ft lbs of torque.
Ram has had the Aisin and the 385hp/865lb-ft Cummins in 2013 until 2016 when they increased it to 900lb-ft. From 2013 to 2015 it was the same frame, trans, and engines yet miraculously it was able to tow over 30k all of the sudden in 2015 when they went J2807 compliant even though nothing changed on the truck from 2014-2015.
Wrong. Ram was rated at 30,000 in 2013. They had many changes to get there.
It never hurts to have a lot of pull, particularly when you’re talking pickup trucks. So for 2013, Ram has upgraded its 2500 and 3500 Heavy Duty pickups, the latter trumping the competition by quite a margin. The 3500 Heavy Duty has had its trailer capacity bumped up to 30,000 pounds compared it its nearest competitor’s 23,100 pounds. What’s more, it’s GCWR (Gross Combined Weight Rating), which includes the weight of the truck, trailer, and the load being carried, has been upped to 37,600 pounds compared to the other guys’ 30,500. Ram 2500s have had their capacities also increased to 18,350 and 25,000 pounds, leading the 3/4-ton class. Also new for 2013 are a factory-integrated fifth-wheel and gooseneck hitch mount, a 17,000-pound Class V hitch with 1800 pounds of tongue weight, and electronic stability control for dual-rear-wheel layouts. Very handy will be a camera mounted in the high-mounted stoplight to make it easier when hooking up the likes of a fifth wheel. Making all this work required a myriad of changes. The frame now is of 50,000-pound-per-square-inch, high-strength steel, which now houses a new suspension. The transfer case, transmission, and 6.7-liter Cummins turbo-diesel all were upgraded, the latter now with 385 hp and 850 lb-ft of torque and—important to budget-conscious haulers—15,000-mile oil change intervals.
Also improved to match the higher ratings were the cooling system, driveshafts, and U-joints. A new active-air-intake system allows for extreme heat or high altitudes and both engine- and transmission-cooling systems have dual radiators/coolers.
