swimmer_spe's avatar
swimmer_spe
What is this?
http://s1279.photobucket.com/user/micheal_can/library/Mobile%20Uploads
This is a picture from inside my 1975 TT. It looks like a power point, like a cigarette adapter.
Is it? If not, what is it? I as because I want to run a voltage adapter to run my laptop at.
  • The voltage gauge is handy, hopefully it is wired directly to your battery. My 1971 Travelaire had a voltage gauge.
  • hmknightnc wrote:
    Get a multimeter and verify that it actually is a 12 volt connection. You should see 12.2 - 12.6 volts if on battery only or around 13.6 volts if your TT is plugged into electrical power.
    Thank you, will do that.
  • Get a multimeter and verify that it actually is a 12 volt connection. You should see 12.2 - 12.6 volts if on battery only or around 13.6 volts if your TT is plugged into electrical power.
  • opnspaces wrote:
    Looks like a 12 volt port with a voltage regulator above it.
    So, I should be safe to plug into it and use it like I do my power outlet in the truck?
  • JJBIRISH wrote:
    It looks like a 12v receptacle but there are different sizes of them hard to tell what size it is…
    There are three sizes…
    6-volt cigar lighter receptacle and plug
    Receptacle inside diameter: 21.34 - 21.46 mm (median 21.4 mm)
    Plug body diameter: 21.08 - 21.23 mm (median 21.155 mm)
    12-volt cigar lighter receptacle and plug, size A
    Receptacle inside diameter: 20.93 - 21.01 mm (median 20.97 mm)
    Plug body diameter: 20.73 - 20.88 mm (median 20.805 mm)
    Most often used in American automobiles.
    12-volt cigar lighter receptacle and plug, size B
    Receptacle inside diameter: 21.41 - 21.51 mm (median 21.455 mm)
    Plug body diameter: 21.13 - 21.33 mm (median 21.18 mm)
    Most often used in European automobiles, and sometimes as a second socket in American automobiles expressly for DC power connections.
    What is the gauge for?
  • Looks like a 12 volt port with a voltage gauge above it.
    Edited to change the text from voltage regulator to voltage gauge.
  • It looks like a 12v receptacle but there are different sizes of them hard to tell what size it is…
  • I tried using the flash, but it made it all white.
    Here is the album with the added pictures.
  • I tried to see the pics but couldnt see them because they are very dark. Is there anything we can do to lighten them?
