speediq99 wrote:
Thank you for sharing this information.
The reason for this question is that we ordered two trucks, a RAM 3500 DRW LB and an F350 DRW LB. The RAM came in first so we took it. The Ford is getting built. From the sound of responses, it sounds like either truck will do just fine.
MC
I don't think uphill towing performance would be a determining factor with those two trucks, both should perform about the same. The Ram probably has an advantage downhill with the exhaust brake and definitely has an advantage with the CP3 pump vs the CP4 pump that Ford continues to use. The Ford has a better transmission and is probably a more reliable truck minus the engine. They're both good options overall.
