GordonThree
Jun 02, 2016Explorer
Most of my mods:
1. Added four G31 AGM batteries under the dinette
2. Wired a "whole house" Magnum 2800 watt pure sine inverter + 125 amp charger
3. Added 90 watts of outdoor LED flood lights for night time parking (actual watts, not incandescent equivalent)
4. Added 180 watts of heating pads to the storage tanks
5. Added a 12-gauge extension cord run inside the frame rail to connect the rear shore power entry to truck bed generator
6. Insulated and added heat trace tape to sewer plumbing
7. Insulated and added heat trace to outdoor water tubing
8. Installed a computer controlled 12v micro pump to circulate hot water in the winter, keep tubing from freezing
9. Removed the low end oem light weight stab jacks, replaced with 5000 lb rated BAL jacks
10. Installed a Wilson Sleek 4G-V inside a cabinet, wired to an external marine mast cell antenna
11. Replaced the manual tongue jack with a Barker electric
12. Replaced the single propane tank holder with a double tank holder
13. Added a auto changeover propane regulator
14. Replaced no-name radio and speakers with Pioneer unit, amplifier and subwoofer.
15. Replaced antenna switch plate with a Winegard Sensar Pro
16. Replaced interior incandescent with custom built ten watt LED lamps, ten total
17. Added 40 watts of high output LED strip lights over the counter-tops and dinette
18. not done yet...
18. not done yet...
44,025 PostsLatest Activity: Feb 18, 2025
