FastEagle
Jun 11, 2013Explorer
myredracer wrote:
I am wondering what it is in the design of a trailer's frame and suspension or otherwise that gives it a particular GVWR rating. Is it the axles primarily?
We have a trailer with a GVWR of 6800 lbs but it weighs in at 6600 lbs without much of any significance loaded into it. We are having serious frame issues (on a new trailer!!) and need to re-inforce the frame and strengthen it due to extreme flex and movement of spring hanger brackets. This will add weight though. The weight of steel will cause the GVWR to be exceeded. We *could* replace the 3500 lb axles with 4000 lb ones. The I-beam needs strengthening and when done should be able to carry more weight. The axles do not see the full weight of the trailer since some is on the tongue (almost 1000 lbs in our case). Due to an excessive side to side movement of the spring hangers (they are tall at 6" high) they will get tied together from one side to the other and we may use the Mor/Ryde crossmembers. The bushings in the spring hangers are worn out all ready and our trailer is only 2 months old and we have only towed it about 100 miles. The frame is already showing signs of failure. There is also substantial bounce in the rear of the trailer and I think some may be due to vertical frame flex. Very poor design. FWIW, welding is not the best.
With all the remedial work needed on our frame, will it effectively raise the GVWR? Is it even possible somehow to get it re-certified with a higher rating?
Read item #8 in this reference.
Click Here!
FastEagle
44,070 PostsLatest Activity: Jul 25, 2026
