Ron_Gratz
Jun 13, 2013Explorer
Gil, there are many ways of establishing a trailer's GVWR.
Just from looking at manufacturer brochure numbers, is seems that some of the possibilities are:
GVWR = the sum of the ratings for each axle.
GVWR = the sum of the ratings for each axle plus an assumed addition for tongue weight.
GVWR = the sum of the load capacities for each tire.
GVWR = the sum of the load capacities for each tire plus an assumed addition for tongue weight.
GVWR = the maximum load which can be carried without exceeding the allowable stress at any point in the frame or suspension system.
In the first post, you mentioned having two 3500# axles. Based on the first two "methods", that should give you a GVWR of at least 7000#.
Have you looked at the DOT (assuming you have US-rated tires) "MAX LOAD" rating for the trailer tires? Multiplying that value by 4 would give another indication of possible GVWR.
Assuming each tire can carry more than 1700#, then it seems likely that KZ has performed a frame strength analysis and used that as the basis for establishing GVWR.
The KZ Spree Specifications Page shows 23 models -- all with 15" tires. There are nine GVWRs ranging from 6000# to 9500#. One model shows a GVWR of 7900# and three show 7950#.
If they really do have GVWRs which differ only by 50#, that does seem to increase the likelihood the GVWRs are based on frame strength.
But, that's just speculation on my part.
Ron
Ron
