mike_kellie
Dec 12, 2019Explorer II
We have the Q1200 with thermometer and we often do a flat bread pizza with dough balls from our local bakery. It can get really hot, enough to sear but you lose the temps fast when opening it. You can also use foil like a gasket to create smaller vents at the sides. I removed the regulator from the grill and installed a 1/4" cross (replacing the tee after the regulator in our camper) with a ball valve and had a 12' long hose made with conventional female ends (not quick coupler)to plumb direct to our 30# tanks. No more small bottles, quick to set up and portable enough to be under the awning or behind the camper.
It can be messy with the drip pan but it stores easily in the basement.
