- 93Cobra2771Explorer
hawkeye-08 wrote:
We planning a 24x50, maybe 28x56. It will fit on the end of our house. I want to be able to park my pickup with it (hooked up or not). On the house side, we are planning a narrow deck along the end of the house so we can load/unload easily. We already have 30A power connection there.
If I only wanted to cover just the TT, I would go alittle longer than the trailer and wide enough for doors to open and slide to be out.
I would have done the full length to fit truck and trailer hooked up - however, the lay of the land would have caused me to have to move a WHOLE bunch of dirt to make that happen. As it was, I had to cut down 3' in one corner for my 20x40 to fit. - gheicherExplorer18' X 21' X 8' carports.com Installed sides myself with material from local metal roofing/siding shop.
- fallsriderExplorerI would love to have one, but the TT has to be parked only about 3' from our side property line, between my storage building and the line. We would not be able to get a permit approved.
If I have known 10 years ago that we would eventually have a TT, I would have built my 12x12 storage building several feet further away from the line. I embedded 8' cinder blocks into concrete footings, and the floor framing of the building is bolted to the blocks. Moving it would be quite a chore. - hawkeye-08Explorer IIIWe planning a 24x50, maybe 28x56. It will fit on the end of our house. I want to be able to park my pickup with it (hooked up or not). On the house side, we are planning a narrow deck along the end of the house so we can load/unload easily. We already have 30A power connection there.
If I only wanted to cover just the TT, I would go alittle longer than the trailer and wide enough for doors to open and slide to be out. - martiprExplorerMy TT is 28' long with a slide making it 11' wide with slide out. My carport is 30x18' with 12' legs. It is on a 32x20' concrete pad. The extra width gives room for the extended steps and a couple of chairs. I wish it was a couple of feet longer. If you are going to put out the money for a carport don't scrimp on the size to save a few bucks. Just my opinion.
- PAThwackerExplorerMy father uses a pole barn. 12h 24w door. 50ft depth and side covered pad. My htt lives on the side pad during the winter
- BurbManExplorer IIIMine is 0' by 0'....
- 93Cobra2771Explorer20x40. 12' legs. Big enough for a fifth wheel should we ever get one.
- wrenchbenderExplorerLearned from mistakes of the past, I would go with the largest one that will fit your budget.
- rbpruExplorer IIMy carport was installed for my PUP. It is only 20 ft. long and would have to be raised up on cement piers to clear the TT.
I may do it because it would provide some protection from the sun and weather.
44,066 PostsLatest Activity: Oct 04, 2013
