A TH may not be your best choice. Look at access to the bathroom & kitchen. Some TH may not have the same heat & cooling in the back portion. Consider checking with a manufacturer like Northwood (Arctic Fox & Nash. They have made handicapped units in the past by enlarging & changing the bathroom door & shower. They also will omit one side of a dinette if you want to keep storage to enable wheelchair/ mobility chair access. These changes can be paired with either a ramp or power lift to the RV entrance. Just another thought... Best of luck on your new choice.
