jerryrigged
Mar 15, 2016Explorer
carringb wrote:
As mentioned above, the E350 v10 or diesel can tow more than 10,000 pounds with an aftermarket hitch. The published tow rating is limited by the factory hitch and not GCWR like most vehicles.
E-series GCWRs
V10/3.73 = 15,000
Diesel/3.55 = 16,000
V10/4.10 = 18,500
Diesel/4.10 = 20,000
V10/4.56 = 22,000
I've towed over 200,000 miles with my v10 and I'm coming up on 420,000 overall. Typical combined weight is 22,000 but sometimes over 25,000. It does great. I did upgrade mine to a dually for more rear axle capacity (because my load in and on the van can top 4,000 pounds + tongue weight) but even stick it could handle that trailer as long as weight distribution is used.
Looking at 2005 E-350, for example, I see several vehicles that are v-10, geared 4.56, and
E-350 6.8L V-10 10,000 (i)
E-350 6.0L TD 10,000 (i)
E-350 Ext 6.8L V-10 10,000 (i)
E-350 Ext 6.0L TD 10,000 (i)
E-350 Wagon 6.0L TD 10,000 (i)
Mpg 7-9 city, 10-11 highway, and that is without a trailer. Yukon/Suburban 8.1L is probably a tad better than this.
Update: Ok, just figured out that TD = Turbo diesel, and "Ext" means extended cab. Slow learner here :)
There are also several Chevy Express/GMC Savana's that are rated at 10k lbs, that I havent listed.
44,060 PostsLatest Activity: Mar 28, 2026
