timmac wrote:
I am planning on downsizing my class A to a B+ rv under 25 foot, was also looking at new trucks and a camper as a 2nd option, so with the price of a new F-250 to F-350 and a new camper with a slideout it would cost almost the same price as a new small class A motorhome, {$100,000+}
The BT cruiser class B+ new starts at $72,000 and has twice the room of most campers..
How in the world does the truck camper makers stay in business with these high prices..
:h
Truck campers are specialty tools. And many don't stay in business, they make up a tiny percentage of the RV market. If you look at all the parts, they are cramming all the same parts into a smaller package. The box itself is a small part of the cost of an RV.
Now to your comparison...I question the comparison of costs you made (I'm using new prices as used prices have to many variables but like for like should follow a similar pattern):
- Class B+ may be $72k but you presumably have a separate car. Average new car price is $35k...let's say you downsize a bit and go $28k...that gives us a baseline of $100k for the motorhome option. Even if you say you aren't going to pull a toad, you still need a car for at home (A $100k class A would be $128k with toad)
- Travel Trailer: A 25ft B+ is going to have interior space roughly equivalent to a 20-23ft travel trailer and could easily be pulled by a 1/2 ton truck. It's no where close to the level of needing a 3/4 or 1 ton truck. We just bought a new 28ft trailer for $18k out the door...saw some smaller ones that we could have got for $15k. Add $35-40k for a 1/2 ton truck to pull it and you are around $50-55k and the truck can be your daily driver. Yes, it will use a little more gas but it will take many years to make up the $45-50k in up front savings.
- Truck campers really are a tough nut unless you need a tool that does what a truck camper does. Even the biggest will have a smaller living quarters and less storage than the other two options. Due to the weight unless you go incredibly tiny, you are at least into a 3/4 ton but more likely in 1 ton truck territory. On the positive side, unless you are pulling a trailer behind it, not much point in upgrading to the diesel...in fact diesel hurts as it eats up payload. So $60k for a truck plus say $40k for a modest truck camper and you are at the Class B+ price. You don't need a toad as you can use the truck for running around.
So why would someone go truck camper?
- They like to go offroad camping. Short of dedicated expedition vehicles, the others won't do nearly as well once you get away from the paved roads. Sure you can creep down a dirt road with most RVs but once things get rough, most people won't want to take their RV any further while truck campers may be happy to keep going.
- If you want to tow something like a boat. Double towing with a travel trailer is illegal in most states (5th wheels are more doable). With a MH, you have the choice of toad or toy.
There are probably a couple other use cases that could be argued but it's mostly a specialty tool.
