profdant139
Nov 22, 2015Explorer III
What thickness of Coroplast for enclosing TT underside?
I'm starting to get serious about adding insulation under my TT, especially under my tanks. (We had our first water line freeze recently, while camping in 11 degree weather.) I am planning to use styrofoam board for insulation, with Coroplast underneath to hold it all in and protect it. I will use self-tapping sheet metal screws, with washers, to fasten the Coroplast to the frame. (By the way, does that sound about right??)
So I went onto the Home Depot site, and they have many different thicknesses of Coroplast, from 0.157 inches to 0.393 inches. Usually, I would opt for the thickest one -- bigger is better, right? But are there pros and cons that I am not seeing? For example, are the thicker pieces more brittle or more prone to sagging?
Thanks in advance for your input!
