- sososixmpgExplorerThanks everyone!!! BREAK-a Way Campers in Sanderville Mississippi, had a Qualified Rim for $40.00. A small price to pay as opposed to not having one and the hunt is over and I got my spare. Ps... The tire at Firestone was $66.00.
- A truck wheel may or may not fit.
Most trailers with a 5 lug bolt pattern use 5 on 4.5"
You will need to find out the bolt pattern, then find a wheel to match.
Etrailer.com is one source for wheels. - mboppExplorerCheck the axle manufacturer's website. IIRR Dexter specs were 4-1/2" bolt circle, 1/2" studs, 0 offset. Old Ford rims were a 4-1/2" bolt circle, the new ones are probably metric.
- eHoeflerExplorer IINeed to check off set, pilot diameter, bolt circle diameter, width, and weight rating.
- alcaracuExplorercheck the offset. most trailers require 0 offset.
44,047 PostsLatest Activity: Aug 12, 2025
