Me_Again
May 15, 2015Explorer III
path1 wrote:
Empty---65 psi
Towing---80 psi
If I disconnect sway bar, how much will I miss it going down the road or will I? Or maybe no way to tell till I give it a try???
If I understand it correctly, you have a bumper pull trailer. Why would you ever inflate the rear tires to 80 psi. That gives a rear axle capacity of 6830 pounds. Given that your rear axle is well under 3K empty and you have maybe 1000 lbs of hitch weight, 55 or 60 psi is more than enough.
Next question is are you putting on the equalizer bars before trying to pull the trailer out???? If so that is a big mistake, just drop the hitch weight on the truck for better traction.
Sway bar disconnected, I think the only thing you will notice is a better riding truck. If you had a truck camper you would want it.
Oh and why air bags with a bumper pull trailer?
Chris
44,056 PostsLatest Activity: Jan 12, 2020
