KampfirekidExplorerJul 15, 2013What to Do With Holes in A-Frame?I removed the Reese Dual Cam from our trailer and prepped it to receive the Equalizer set-up. There are holes left in the frame that I was going to put rubber plugs in to prevent water entry. Should...Show More
KampfirekidExplorerJul 15, 2013Thanks. The sealant idea is great as it will last longer than rubber plugs due to UV exposure alone.
Related ContentBroken Frame on a RAM 3500Replacing a A-frame Jack, need to enlarge 2" hole to 2-1/4"bent a-frameA-Frame Damage2004 Chalet A-Frame
