cbshoestring wrote:
Electrical work should only be performed by a licensed professional. The below information is for informational purposes only.
You removed a black (vent) wire from two purple wires....reconnect those purple wires with a wire nut & electrical tape around the wire nut for added peace of mind.
You removed a white (vent) wire from two white wires....reconnect those white wires with a wire nut & electrical tape around the wire nut for added peace of mind.
If they had been wired seperatly....why oh why would you consider wiring the four of them together :h
RE-READ above section in RED.
I'm just trying to learn how this works.
