LIKE2BUILD
Feb 13, 2016Explorer
rangerbait wrote:
Awesome, thanks for the suggestions! So, Butyl Putty between the flange and siding, then calking around the edge then?
You can caulk around the edges but it's not a must. If you put plenty of putty in there, then run it down snug with the screws, you should get putty to squeeze out. If you trim that off it should be good enough. But, if you prefer you can use a little caulk to seal that edge.
KJ
44,066 PostsLatest Activity: May 13, 2026
