Edd505
May 25, 2019Explorer
asullivan920 wrote:
Always love reading the tool lists! Every once in a while I find something to add to my own kit.
This is what I carry with out going into tiny details.
Always in Tow vehicle.
Jack (I use have a HI-lift and a bottle jack)
wood blocks (to use jack on soft soil or make it reach)
set of tire chocks
jumper cables
tow strap
12V air compressor & tire pressure gauge
6X9 tarp (never know what you may have to lay down on or in)
5 gallon bucket (use as a seat or part of a spill kit)
Tool kit
Socket and wrench set (going up to 1.5 in and 24mm I think)
Adjustable wrenches from a small 6in to 24in
many sizes and types of screw drivers
duct and electrical tape
electrical connector kit
Knife and hack saw
hose clamps small to 6in sizes
bailing wire and 550 cord
torc wrench
Tire iron that fits truck and trailer
Full size spare (remember if you put larger tires on your vehicle your OEM spare is not full size any more)
Fluids (windshield washer, anti-freeze, brake, power steer, and oil + filter)
Hammer 3lb and regular claw hammer
Trailer:
More wood blocks
impact gun with sockets for wheels and stabilizer jacks
shovel
lever for stabilizer hitch
hand crank for stabilizer jacks
spare tire
2 sets of chocks
extension cord
generator
grease gun
As far as maintenance goes before you head out.
Truck:
check all fluids (maybe change before long trip)
check air filter
check all tires to include spare and make sure the spare comes down.
Trailer:
check all tires to include spare and again make sure it comes down.
check all lights
check brake away system
depending on how long between (check brakes and lube bearings)
I also just pulled my trailer out of storage and never used it last year. Set it up in the driveway for a few days. Made sure every appliance worked. Check to make sure the fridge and hot water heater worked both on gas and power. Put out the awning, changed batteries in smoke and carbon monoxide alarms, charged and checked water level in batteries, kicked on furnace/AC, and the sanitized water system.
good list:
add Flash light, spare batteries for what ever battery power stuff you have, command hooks, scissors, super glue, a small assortment of nuts, bolts, & screws ( I carry an old coffee can and put stuff like that in when I find it) Volt/Ohm meter, test light, spare fuses, bulbs (always in two packs so I end up with a spare) WD or Break Free, cordless drill & extension cord.
44,071 PostsLatest Activity: Sep 17, 2026
