rhagfo
Feb 17, 2016Explorer III
Grit dog wrote:agesilaus wrote:
With a 3/4 ton truck your main concern will be payload. That is usually the limiting factor on what you can safely tow. Adding things like heavier springs will not affect the strength of your vehicle axles which is the final controlling factor on your truck.
Been hashed out about 100000000 times on here. Axle is the same as 1ton. Load er up. Have to be a huge 5ver to overload a AAM 11.5 axle.
Agesilaus, wrong on that count, as mentioned the axle is the same 10,000# axle as one ton.
The REAL LIMITING factor is TIRES!!!
44,056 PostsLatest Activity: Nov 19, 2013
